Intel® Desktop Boards
Peer-to-peer support only
Welcome to the Intel Community. If you get an answer you like, please mark it as an Accepted Solution to help others. Thank you!
11360 Discussions
BIOS 0152 on DH87MC
RHarv1
Hi Team,
Small problem relating to updating BIOS on DH87MC to version 0152.
Since update I am getting warnings about Memory temperature exceeding its maximum recommended temperatue and showning a temp of 79 degrees C.
This is causing the CPU fan to increase its speed and is making the system noisy. No other changes to system and I am using approved memory.
This problem did not exist in BIOS 0147.
When I touch the simms they are cold - surely if they were 79 degrees as desktop utilities monitor suggests I would burn my fingers or at least feel some heat.
In the 0152 BIOS readme there is the following "fix" listed:-
Fixed issue in Intel® Desktop Utilities with inaccurate VR and
memory temperature readings.
Does this mean that I have had memory temperatures too high for a long time and now the new BIOS recognises the fact or is the new BIOS giving false readings?
Any advise greatfully received - I've worked hard to build a silent PC and it's no longer silent.
Silvia_L_Intel1
Hello Aybracers, we are working on a new BIOS in order to fix this behavior. For additional information please check the following threads /thread/47057 https://communities.intel.com/thread/47057 and /thread/45877 https://communities.intel.com/thread/45877.
