Hello there everyone,
I'm currently working in a older machine that i recently got and decided to make the latest updates and support possible for that board. But the main factor that i'm having problem is with the BIOS, where i'm looking for the MO0400P.BIO for download to make the transition of the 10J version to 10N and finally doing the other steps of customizing and rebranding it and i don't find anywhere. Anyone in the community have this specific BIOS? If yes, could you send to me?
Cheers.
I have attached ZIP file containing both BIOS 400 and BIOS 542 (the last produced). Release Notes are also included.
Note: I recommend installing these updates using the BIOS Recovery process. For information on the BIOS Recovery process, consult Intel Desktop Boards Recovery BIOS Update Instructions.
To help you better, here are my step-by-step instructions for BIOS Recovery:
- NOTE: Read these instructions completely before starting. Follow all instructions EXACTLY.
- On some other Windows-based PC, make sure that you have the .BIO file for the BIOS release you wish to install.
- Insert a 32GB or smaller (the smaller the better) USB 2.0 flash drive into the PC. Do not use USB 3.0 flash drives (most are not compatible). It is also best if you use a flash drive that has an access LED that you can watch.
- Format this USB flash drive using the Windows Format applet. Select to install the FAT32 file system (NOT vFAT, NOT exFAT; FAT32 only). You must also specify that the Quick Format option be Disabled (unchecked).
- NOTE: If FAT32 is not offered as a choice by the Format applet, your flash drive is too big; use another.
- Copy the .BIO file into the root folder of this USB flash drive. This should be the only .BIO file in the root folder of the USB flash drive.
- Properly eject the USB flash drive. Do not just yank it out. Do this from File Explorer or using the Safely Remove Hardware and Eject Media System Tray applet.
- Power off the Desktop Board system.
- Remove the yellow BIOS Configuration jumper from the board. It will be the only yellow jumper; the rest will usually be black.
- NOTE: Remember the pins that this jumper was plugged onto; you will need this information later.
- Plug the USB flash drive into one of the black USB 2.0 ports on the back panel of the board. Do not use blue or yellow USB 3.0 port. Do not use any front panel USB ports.
- Power on the system.
- The BIOS Recovery process should start automatically. You should see a progress report on your main monitor.
- NOTE: If you do not see a progress report displayed on a monitor, do not power off the system for at least 15 minutes. While it is rare, it is possible for the process to proceed without an onscreen display; you must give it ample time to complete, just in case.
- When the BIOS Recovery process is complete, you will be asked to power off the system. Do so.
- Restore the yellow BIOS Configuration jumper to the pins it was on previously. This should be across pins 1 and 2 of this (three pin) header.
- Remove the USB flash drive from the back panel of the board.
- Power on the board.
- Immediately begin pressing the F2 key, over and over (approx. once per second) until you see the BIOS Setup (or Visual BIOS) screen displayed.
- Verify, using the BIOS version string, that the BIOS installed properly. Stop if it isn't.
- Press the F9 key (followed by the Y key) to reset of the BIOS configuration.
- Press the F10 key (followed by the Y key) to save the BIOS Configuration and exit BIOS Setup.
- Once screen is cleared (goes black), begin pressing the F2 key, over and over, until you see the BIOS Setup screen displayed.
- Make any changes to the BIOS configuration that you desire (for example, disabling NUMLOCK) or that you require (for example, setting Boot Order, enabling UEFI, etc.).
- Test.
Hope this helps,
What is the exact, complete bios string you have right now?
The complete bios string is MOPNV10J.86A.0311.2010.0802.2346
- Test.
Hope this helps,
I don't have enough words to say how much I thank you, it was very difficult to find anything to that model besides drivers and i see this mobo model it's not that common. I appreciate a lot your kindness.
Cheers and be well!
- Tags:
- don't
Enjoy! And let me know if you had success doing the upgrades.
As you asked for a replay with the results, both updates worked very well. Now it's on the final version and working pretty well thanks to you.
Thanks a lot.
