Intel® Desktop Boards
Peer-to-peer support only
11428 Discussions
BIOS memory error on DQ77KB
SDiac
I have a DQ77KB mother board with intel i3 3220T processor.
I have update the BIOS to v52. After the upgrade, I have reboot, check the BIOS and reboot again.
Now, I have a black screen with 3 long beeps (memory error) and impossible to boot.
The memory is OK, I have test it with an other safe memory module and I have the same problem.
I can't go in the BIOS setup, the screen is black before. I have try to reinstall BIOS this "F7", and also to restore it with the BIOS jumper.
I have also try to "clean" the BIOS : unplug all cable, remove the BIOS battery, wait 30 minutes. The problem still the same.
I think the BIOS is corrupted but I don't know how to restore a clean BIOS. If you have any idea...
Best regard,
Stéphane
Silvia_L_Intel1
Hello Stephane_D,
Do you remember which was the BIOS version installed before you updated it to the latest one (0052)? We can try doing a BIOS recovery installing the previous version.
These are some recommendations for this issue:
If all this troubleshooting does not resolved the problem, I recommend you get in touch with our Warranty Department so they can help you to replace the unit: http://www.intel.com/p/en_US/support/contactsupport http://www.intel.com/p/en_US/support/contactsupport
Regards.
SDiac
Hello Sylvia,
I have try all this method, all will try again them just in case.
I'm sorry but I don't remember the previous version, I think it was the v38 but I'm not sure at all.
If it's can't help, I have upgrade because I did't seen any option to go on the MEBX menu (with Ctrl+P).
Thank you for your help even if I was dreaming about a magical solution to solve that.
Stéphane
Silvia_L_Intel1
Stephane, you may want to perform something else before replacing the motherboard,
  • Please download BIOS version 0038 (.bio file) save it on an empty flash drive.
  • Remove all hard drives, optical drives and leave only 1 memory stick.
  • Remove the BIOS jumper while the system is off.
  • Plug the flash drive and turn on the system. You may be able to see the screen while the BIOS is being update, if not, please wait for a few minutes.
Please let me know.
