Community
cancel
Showing results for
Search instead for
Did you mean:
Highlighted
Community Manager
BIOS reset/flashed out every time when computer ON after shutdown - Intel X58/ i7 CPU 920 @ 2.67 GHZ
I have problem with my PC, BIOS reset/flashed out every time
when computer ON after shutdown. When restart no problem only when I shutdown
PC and try to start first It could not start right way wait 2-3 minutes try
BIOS flashed out/reset every time again
change setting. I tried everything possibilities like check memory, CPU, Graphics card and others
devices but failed to figure out problem may be problem in board. Please help
me if I replace board which is compatible for i7 detail is given below:
MotherBoard – DELL INC, Chipset – Intel X58, Product – 0R849J
Processor – Intel(R) Core(TN) i7 CPU 920 @ 2.67 GHZ
Memory – 10 GB DDR3
OS – Windows 7 Ultimate 64bit
Highlighted
Have you tried contacting Dell support.They should have a better idea as to what is causing this problem.
Have you tried downloading the latest bios/firmware for your computer?You can look for your system specific updates on the Dell website.
Highlighted
Community Manager
i tried there is no update for bios, Dell suport charge last year i already buy extended waranty every year spend money. its better replace motherborad
Highlighted
Honored Contributor I
First , you do not want to update a Dell Board with a Intel BIOS they are different Dell writes there own BIOS. you could Brick your board by running a Intel BIOS on a Dell Board .
Highlighted
Community Manager
Thanks for update. Please guide me how i fix my problem. how i change BIOS Dell to Intel i tried find BIOS software for this board but there was no BIOS provided by Intel for Intel X58 board.
Highlighted
You cannot run Intel bios on Dell motherboard.
DO NOT TRY IT THIS WILL KILL YOUR MOTHERBOARD.
YOU WILL HAVE TO LOOK FOR DELL UPDATES ON THE DELL WEBSITE.
Highlighted
If you have purchased extended warranty you can always contact dell support.They will help you.
Highlighted
Community Manager
but now warranty expired. you know without money they did not help.
Highlighted
Community Manager
i know that i am waiting for update but still no update bios released by dell. i always turn on my pc. I also checked my Dell PC check it shows no problem found. i thought overheating problem and i cleaned fan, heatsink and replaced BIOS battery also but still problem i could not understand why BIOS flash after shutdown.
Highlighted
Have you tried to over clock your cpu without proper cooling?
Have you made any changes in the bios settings?
Highlighted
This might be a bit late. But if in future, anyone has this similar problem, hope this will help.
The motherboard stores all BIOS and Time in the motherboard, which is powered by a CMOS battery. If the battery is dead, then every time you power off, all the settings are lost. Replacing the CMOS battery would solve this problem. Check if system time is also getting reset or being messed up after a complete shut down and power off. If it is, then it is definitely a dead CMOS battery.
