Intel® Desktop Boards
Peer-to-peer support only
Welcome to the Intel Community. If you get an answer you like, please mark it as an Accepted Solution to help others. Thank you!
11360 Discussions
BOXDZ77GA-70K wont boot or beep
BDole
All,
My motherboard wont boot up or beep, error code on my led is showing 04. i've unplugged everything and replugged it all in and still nothing.
Current setup for my pc is
600watt psu
960 gtx
multiple hdds, but i've unplugged all except one the primary SSD/HDD
unplugged all usb connections.
unplugged all case fans.
From what i can gather, mobo still works because when i removed ram it beeped stating no memory installed.
would removing the battery off the mobo be an option?
or flashing bios, i've never done it before.
n_scott_pearson
Super User Retired Employee
These are Power-On Self-Test (POST) codes, not error codes. While a few codes are reserved to indicate that specific types of errors have occurred, the majority of the POST codes simply indicate that the BIOS has reached a certain point in its initialization and testing processes. POST Codes 0x00 - 0x0F are reserved for use as interim progress indicators within individual drivers/processes in the BIOS. Thus, seeing POST Code 0x04 by itself doesn't really tell us anything. If you can write down the sequence of POST codes you see occurring prior to this (final) code, it would help us narrow it down...
BDole
a bunch of numbers flash by quick but,
the number 31 appears and is solid for a few seconds, and then it goes back to 04.
n_scott_pearson
This means the board is unhappy with the memory. It cannot initialize it.
BDole
suggestion towards fixing this problem?
n_scott_pearson
You might have to replace the memory you are using...
BDole
replaced ram sticks and still nada.
the led lights up as follows
04
31- for about 10 seconds.
cycles through a bunch of numbers
20
power cycles down and stays off for awhile and then power cycles on again
all the fans spin, no beep, nada.
EstebanA_C_Intel
Hello, tk1134:
I would like to know, did you double check that the memory used does comply with the supported memory in the motherboard and your CPU?
Page 22 of this PDF has the information related to the Motherboard: https://downloadmirror.intel.com/20956/eng/DZ77GA-70K_TechProdSpec04.pdf https://downloadmirror.intel.com/20956/eng/DZ77GA-70K_TechProdSpec04.pdf
You could check the processor's supported RAM by looking for the model you have here: http://ark.intel.com/ ARK | Your Source for Intel® Product Specifications
Esteban C
n_scott_pearson
Yes, seeing POST code 20 last is an indication that it is getting stuck in Memory Configuration. The replacement RAM seems to have the same issue - it is (also) incompatible or something has failed on the board.
EstebanA_C_Intel
Hello:
For sure, testing the RAM in the different DIMM slots in your board would be a good troubleshooting step to follow.
I look forward to your outcome with this.
Esteban C
BDole
I bought another set of ram and applied it to mobo, no success. I put the new ram sticks in every slot and combo, nothing worked. Retried old ram sticks to see if I got any other combos(led numbers). Maybe it was a bad set of ram sticks from microcenter wouldn't be the first time. Will return and swap out and try again.
Orginal stick cmx8gx3m2a1600c9 8gb
Replacement cmz8gx3m2a1600c9 16th
Do you think the mobo is fried?
I believe limited warranty is still covered as its only been one year from amazon purchase
n_scott_pearson
If you purchased it new, you have 3 year warranty. You need to contact ICS directly to request RMA...
