Intel® Desktop Boards
Peer-to-peer support only
This community is designed for sharing of public information. Please do not share Intel or third-party confidential information here.
11460 Discussions
Beep Code for Intel Desktop DP55WB mother board
EPagl
A custom built (older computer) just started having the following problem: On boot up, no graphics, and the following beep code 2-1-1-1
I swapped memory around with no impact.
The processor is a i7-860 (LGA1156)
The graphics card is a NVidia GEFORCE GT610 which was replaced in Jan 2013. I haven't tried swapping it out until I understand the beep code.
Thanks for any suggestions.
IUman
Hello epags,
Thank you for joining the Intel communities.
You can check the beep code here:
http://www.intel.com/content/www/us/en/support/boards-and-kits/000005473.html?wapkw=beep+codes BIOS Beep Codes for Boards and Kits
Ivan
EPagl
Thanks. By accident I discovered the graphics card connection was loose. Your reply confirmed the issue and now I know the two beep significance.
IUman
I'm glad to hear that your issue has been resolved and thank you for letting us know what happened.
