Intel® Desktop Boards
Peer-to-peer support only
Welcome to the Intel Community. If you get an answer you like, please mark it as an Accepted Solution to help others. Thank you!
11359 Discussions
Benötige Treiber für Win 10 ::::: Das Gerät "ACPI\INT345D\3&11583659&0" und für:::"PCI\VEN_8086&DEV_A160&SUBSYS_79941462&REV_31\3&11583659&0&A8" PCI Datensammlungs und Signalverarbeitungscontroller
gleo
Hallo.
Win 10 im Gerätemanager erscheint das nachfolgende Bild.Hat da jemand eine Idee? Danke.
n_scott_pearson
Super User Retired Employee
The dump is telling you exactly what these things are. Sunrise Point is the 100 Series and C230 Series chipset (PCH IC) for Skylake architecture processors. These are controllers for bi-directional transfers on two I2C (bit) buses and via a UART (a type of Serial Communications Port). You need to download the chipset and I/O drivers to resolve these controllers. They should have been provided by your board manufacturer...
Hope this helps,
n_scott_pearson
Hope this helps,
