Intel® Desktop Boards
Peer-to-peer support only
11479 Discussions
Best BIOS to revert to for DQ87PG? Having all sorts of boot issues.
SFles
is just one example I run into. We have hundreds of these PCs in classrooms and we also see the single boot device listed issue as mentioned in the forums.
I did try 153, with the same results. I was hoping that, if after two years, they updated the BIOS, there must be a good fix, but it didn't take care of the issue.
So, does anyone have a recommendation on which BIOS to go back to? I was think 148 or one of the 130s (I think you can't back further than one of the 130 BIOSes, but I can't remember which).
Keep in mind this has nothing to do with the OS, as much as I tried to explain to the person in the above linked topic. I am trying to boot to a USB, whether it be our MDT drives or UBCD on USB, they work on DQ45s through DQ77s and the ASUS boards we've been using since Intel shutdown their desktop boards. This should also tell you it's not an issue with the drives.
n_scott_pearson
Super User Retired Employee
Sean,
Intel exited the Desktop Boards business soon after the release of the 8 Series boards. Once the standard (3 year) warranty period was over, the support team was disbanded and all maintenance work on the BIOS was terminated. The update that you recently saw released was put together by an emergency response team as a result of some serious security issues being found in the Intel Management Engine (ME) firmware. No other parts of the firmware package (BIOS or otherwise) were updated in this process. Unfortunately, due to the business exit, no other type of issue will be considered just-cause to receive similar attention. Do not expect these issues that you are seeing to be fixed in the future; they will not.
It is certainly in the realm of possibility that the problems that you are seeing were introduced after the original production BIOS was released (i.e. were bug(s) introduced in some subsequent BIOS update(s)). Unfortunately, whether you will be able to back your way through these updates (and possibly locate one that doesn't exhibit the issue(s)) is going to be limited by the ME firmware. It simply may not allow you to go back beyond a certain point. If this is the case, you will have to stick with what workarounds you have in place.
My only suggestion is for you to investigate whether the use of (or disabling of, as the case may be) UEFI support makes a difference in boot order handling.
Hope this helps,
SFles
One of my coworkers figured out (about a year ago and didn't share until recently) that 142 still works, so I guess we are going to downgrade to 142. None of the other things I tried in the old thread really worked consistently. You can't even go to 142, then upgrade to 152 and have it work, so Intel must have broken something in between.
I knew they got rid of all their engineers and such, so I figured there must have been a pretty bad issue for them to release a new BIOS, especially this late after it was last updated. I was just hopeful they may have fixed the issue I was running into. That does happen sometime.
Back when I posted the original thread, they PCs were in classrooms and not really under my purview to push for a fix. Now that they are being redeployed to offices, we have to deal with what others never bothered to do. I guess we are fortunate that this guy figured out which version to go back to for the fix.
Anyway, if anyone is having issues with the boot order and boot devices on the DQ87PG, you can revert back to 142 without having to do a recovery BIOS install.
n_scott_pearson
Intel is uncompromising when it comes to security issues. If a security issue is discovered, regardless of the pedigree of the systems, the production of a fix will be mandated. A few months back, a 3rd-party security expert discovered two security holes in the Management Engine (ME) interfaces. Updated ME firmware - for all versions of the ME ever produced - was developed and released.
SFles
So they went all the way back to 35s and 45s...
Too bad the didn't fix other lingering issues. It kind of makes it pointless in the 87 since it's boot order broke sometime between 142 & 148. Now I get to choose between not being able to choose my boot devices or closing some obscure security hole that we'll probably never have to deal with.
n_scott_pearson
Actually, they released the ME firmware update with an installer that is independent of the BIOS. This means that you can install whatever BIOS version you prefer and then install the updated ME firmware over top of the version installed with that BIOS. Bottom line, regardless of which BIOS version you prefer, you can have the fixes for the ME security issues.
SFles
I noticed that after a bit. I was thinking that you might be able to do that.
