Intel® Desktop Boards
Peer-to-peer support only
11476 Discussions
Bios flash update ERROR?
Community Manager
I can not log in to "Windows", before loading this screen appears:
I've tried everything, i think, But this screen always appears .
Thank you!
Community Manager
Hello diegabo,
Thank you for contacting the Intel community.
Do you have any flash driver plug into the USB ports? If yes try removing it and see if you can access Windows, if not, I suggest you to access the BIOS by pressing F2 on your keyboard when you get the prompt and make sure the system is booting from a bootable HDD or when you are in the BIOS press F9 on your keyboard to set the bios to default settings and then press F10 to save the changes and see if you can access Windows now.
Ivan U.
Community Manager
Hello ,
I'm following on this post to ask you if your issue has been resolved or if you need further assistance.
Ivan.
