My problem is that at a time not walking very well came my pc. from time to time ran out video signal among other things. decided to update the bios and format, after that I could not have more onboard sound. I'm using the sound of the video card. in the pc apparently everything is perfect, the only problem is that the sound comes out. attached photo.
*when I plug the speaker or microphone detected but leaves it in the audio panel onboard sound.
I have windows 7 64 bit
ersion of audio drivers: ( AUD_Win8_Win7_6.0.1.6914_PV.exe ) Versión:6.0.1.6914
Hi leoortega,
Can you please post your dxdiag report here?
-Aca te dejo mi reporte del DXDIAG. (ahora tambien cuadno reincio algunas veces no arranca, tengo que sacar la placa de video y hacer un reset de bios para que arranque.)
System Information
Time of this report: 10/9/2013, 12:33:03
Machine name: LEO-PC
Operating System: Windows 7 Ultimate 64-bit (6.1, Build 7601) Service Pack 1 (7601.win7sp1_gdr.130801-1533)
Language: Spanish (Regional Setting: Spanish)
System Manufacturer: INTEL_
System Model: DH61WW__
BIOS: Default System BIOS
Processor: Intel(R) Core(TM) i3-2100 CPU @ 3.10GHz (4 CPUs), ~3.1GHz
Memory: 4096MB RAM
Available OS Memory: 3926MB RAM
Page File: 1471MB used, 6380MB available
Windows Dir: C:\Windows
DirectX Version: DirectX 11
DX Setup Parameters: Not found
User DPI Setting: Using System DPI
System DPI Setting: 96 DPI (100 percent)
DWM DPI Scaling: Disabled
DxDiag Version: 6.01.7601.17514 64bit Unicode
DxDiag Notes
Display Tab 1: No problems found.
Sound Tab 1: No problems found.
Sound Tab 2: No problems found.
Input Tab: No problems found.
DirectX Debug Levels
Direct3D: 0/4 (retail)
DirectDraw: 0/4 (retail)
DirectInput: 0/5 (retail)
DirectMusic: 0/5 (retail)
DirectPlay: 0/9 (retail)
DirectSound: 0/5 (retail)
DirectShow: 0/6 (retail)
Display Devices
Card name: Tarjeta gráfica VGA estándar
Manufacturer: (Tipos de pantalla estándar)
Chip type: Intel(R) Sandybridge/Ivybridge Graphics Chipset Accelerated VGA BIOS
DAC type: 8 bit
Device Key: Enum\PCI\VEN_8086&DEV_0102&SUBSYS_20178086&REV_09
Display Memory: n/a
Dedicated Memory: n/a
Shared Memory: n/a
Current Mode: 800 x 600 (32 bit) (1Hz)
Monitor Name: Monitor PnP genérico
Monitor Model:
Monitor Id:
Native Mode:
Output Type:
Driver Name: vga
Driver File Version: 6.01.7600.16385 (Spanish)
Driver Version: 6.1.7600.16385
DDI Version: unknown
Driver Model: desconocido
Driver Attributes: Final Retail
Driver Date/Size: 7/13/2009 20:38:47, 15360 bytes
WHQL Logo'd: Yes
WHQL Date Stamp:
Device Identifier: {D7B78E66-4242-11CF-37A3-A71DA7C2CB35}
Vendor ID: 0x8086
Device ID: 0x0102
SubSys ID: 0x20178086
Revision ID: 0x0009
Driver Strong Name: Unknown
Rank Of Driver: Unknown
Video Accel:
Deinterlace Caps: n/a
D3D9 Overlay: n/a
DXVA-HD: n/a
DDraw Status: Not Available
D3D Status: Not Available
AGP Status: Not Available
Sound Devices
Description: Altavoces (Realtek High Definition Audio)
Default Sound Playback: Yes
Default Voice Playback: Yes
Hardware ID: HDAUDIO\FUNC_01&VEN_10EC&DEV_0892&SUBSYS_80862017&REV_1003
Manufacturer ID: 1
Product ID: 100
Type: WDM
Driver Name: RTKVHD64.sys
Driver Version: 6.00.0001.6914 (English)
WHQL Logo'd: Yes
Date and Size: 5/21/2013 21:50:42, 3425608 bytes
Other Files:
Driver Provider: Realtek Semiconductor Corp.
HW Accel Level: Basic
Cap Flags: 0xF1F
Min/Max Sample Rate: 100, 200000
Static/Strm HW Mix Bufs: 1, 0
Static/Strm HW 3D Bufs: 0, 0
HW Memory: 0
Voice Management: No
EAX(tm) 2.0 Listen/Src: No, No
I3DL2(tm) Listen/Src: No, No
Sensaura(tm) ZoomFX(tm): No
Description: Realtek Digital Output (Realtek High Definition Audio)
Default Sound Playback: No
Default Voice Playback: No
Manufacturer ID: 1
Product ID: 100
Type: WDM
WHQL Logo'd: Yes
Other Files:
Cap Flags: 0xF1F
HW Memory: 0
Sound Capture Devices
Description: Micrófono (Realtek High Definition Audio)
Default Sound Capture: Yes
Default Voice Capture: Yes
Cap Flags: 0x1
Format Flags: 0xFFFFF
DirectInput Devices
Device Name: Mouse
Attached: 1
Controller ID: n/a
Vendor/Product ID: n/a
FF Driver: n/a
Device Name: Teclado
Attached: 1
Controller ID: n/a
FF Driver: n/a
Device Name: Comfort Curve Keyboard 2000
Attached: 1
Controller ID: 0x0
Vendor/Product ID: 0x045E, 0x00DD
FF Driver: n/a
Poll w/ Interrupt: No
USB Devices
+ Concentrador raíz USB
| Vendor/Product ID: 0x8086, 0x1C26
| Matching Device ID: usb\root_hub20
| Service: usbhub
| Driver: usbhub.sys, 9/4/2013 09:12:11, 343040 bytes
| Driver: usbd.sys, 9/4/2013 09:11:40, 7808 bytes
