Intel® Desktop Boards
Peer-to-peer support only
Boot MGR
mMark12
BOOTMGR Missing
I would like to install an operating system, but cannot even
do this!
The computer had windows 7 on it. The SSD ("hard drive") was
removed and reformatted using another computer.
Now I cannot even load an operating system because after
powering on I just get a message:
"Boot MGR is missing
Press Ctrl Alt Del to restart"
So this is what I have done so far:
  1. Checked all cables
  2. Tried to install windows 10 from a CD
  3. Tried to install windows 7 from a CD
  4. Physically changed the optical (CD/DVD) hardware
  5. Physically changed the SSD "hard drive" to a new SATA
    hard drive
  6. Cleared the CMOS Setting by moving the jumper pins and
    restarting the computer
  7. updated the BIOS (successfully) from a USB.
Each time I start the computer I still get:
Boot Mgr is missing!
Can anyone please help?
Where is this Boot
MGR located?????
n_scott_pearson
Super User Retired Employee
The Boot Manager is installed in the first few sectors of the HDD (or SSD or SSHD). Whatever was done on this "other computer" has wiped out the Boot Manager.
I suggest that, while installing Windows (i.e. booting from Windows installation media), when you get to the scene where you select the partition to install to, make sure that you delete *all* existing partitions. When done, you should see only a single entry for unused space on the HDD. Select to have Windows installed to this unused space. This should restore the Boot Manager.
Let me know if this fixes the problem. There is a second possibility, but I won't go into it until we exhaust this one...
mMark12
Thanks for your suggestions.
I have solved the problem
The SSD is so fast I did not notice the line "press any key to boot from ..."
this instruction appears for less than one second and then it is replaced with "boot mgr is missing"
hahaha
so I pressed the space bar and it worked
Thanks again
Community Manager
Hi Mark117,
Great to know that your system is now working as it should.
If there is anything else you need, do not hesitate to contact us back.
Hellen.
