Community
cancel
Showing results for
Search instead for
Did you mean:
Highlighted
Community Manager
Boot drive order on DH67GD
i use the DH67GD mainboard and have 2 HDDs installed:
P0 with Win7 64bit and
P1 with linux.
In the section "Boot" in BIOS I changed the "Boot Drive Order" to
P1
P0
but the mainboard boots always from P0!
I also changed the "Boot Menu Type" to Normal and Advanced for testing purposes but always the same situation.
UEFI boot is enabled.
I can only boot to P1 when i press F10 for the boot menu an select P1 manually.
What must be set when i want the mainboard to always boot from P1?
Community Manager
What you are trying to accomplish is a dual boot, usually Windows needs to be installed first before Linux, creating a NTFS partition when formatting.
Our recommendation is contacting the Linux authorized support groups for further information and instructions on how to create a dual boot system using these two Operating System (OS).
Highlighted
Community Manager
Hi Dan,
both systems are installed an running very well.
Windows on P0 and
Linux on P1.
What settings do I need in BIOS to always boot from P1?
When UEFI is activated, the mainboard always boots from P0!!! WTF # fail
vlad
