Intel® Desktop Boards
Peer-to-peer support only
Boot failure
SSoom
I dont know what do , i have intel DG41RQ Desktop ....
Error which i can see before boot :-
"This product is covered by one or more of the following patents: S5,305,459 , US5,434,872 n so on ...
For giga ethernet controller:-
PXE-E61: Media test failure, check cable.
PXE-MOF: Exiting PXE ROM."
ppara5
Valued Contributor I
Some boards have strange messages when there is no system drive. Verify that the cable to the HDD-SSD is firmly seated. If that does not help, use a different cable and/or a different port on the board. Also, disconnect the cables to the CD-DVD drive and boot again to see if it has malfunctioned.
IUman
The Preboot Execution Environment (PXE) comes up when the system is trying to boot from network, this can happen when the system has a defective hard drive or no operating system installed.
In this case I would recommend following the steps paramountain mention above, if not try to test your system with different hard drive.
