Community
cancel
Showing results for
Search instead for
Did you mean:
dface
Boot screen in a loop?
Hello all!, early i decided to update my BIOs (DH61WW) because some LAN issues, i have 099 ver. and tried 0120 express method, in first the process fail, and later dont let me start Windows 7 (64 bit), because it is in a loop the boot screen (i can acces f2, f7, f10).
So i decided to do http://www.intel.com/support/motherboards/desktop/sb/CS-023360.htm http://www.intel.com/support/motherboards/desktop/sb/CS-023360.htm a Recovery Bios Update, and it works! but the problem still continue, even i tried other version, and the update is done, but the problem still persist, so i decided go back to 0099, but just this version dont work.
Any thoughts about that?
I tried everything on this posts: /message/265863# 265863 https://communities.intel.com/message/265863# 265863
http://https//communities.intel.com/message/192280# 192280 http://https://communities.intel.com/message/192280# 192280
with no luck.
Thanks!
