Intel® Desktop Boards
Peer-to-peer support only
Welcome to the Intel Community. If you get an answer you like, please mark it as an Accepted Solution to help others. Thank you!
11361 Discussions
Can I install a GTX 750Ti in my dp45sg motherboard?
SJain25
Hey Guys,
Can i upgrade my system with a GTX 750Ti GPU?
The current specs are:
Intel DP45sg Motherboard
Intel Core2 Quad Q8400
8Gb Ram
1tb HDD
MSI 9600 GT GPU
AlHill
The answer is: Maybe
This is your board: http://ark.intel.com/products/34683/Intel-Desktop-Board-DP45SG Intel® Desktop Board DP45SG Product Specifications
It is already nine years old.
It has 2 PCIe x16 2.0 slots. The key here is they are PCIe Rev 2.0.
It seems the video card is from ~2014. I cannot determine if the GTX 750ti is a PCIe 2.0 or 3.0 card. You will need to determine this.
If it is 2.0, you have a better chance of it working, as the DP45SG supports 2.0. If the card is 3.0, then you have a lesser chance. Although the card will probably claim backward compatibility, this is often not the case.
Doc
AlHill
Doc
Community Manager
Hello Siddhanth,
At this point, I suggest contacting your video card manufacturer; they might have a list of compatible motherboards with this graphics card; however, as Al Hill mentioned above this motherboard is old and the graphics card is newer and you could experience some compatibility problems.
Ivan.
