Intel® Desktop Boards
Peer-to-peer support only
This community is designed for sharing of public information. Please do not share Intel or third-party confidential information here.
11462 Discussions
Can not Recover BIOS ?!
Community Manager
So, i have a new Intel DZ77RE-75K
I wanted to update my BIOS, and what a mistake i did to use the WIN utility...
(reading all the problems people got, i wonder why Intel still provide it).
So now, i'm at the point where my PC does not boot anymore (well, come the power, then nothing, black screen).
I removed the Bios Jumper, copied GA0064.BIO on USB flash, reboot, waited long time.
But nothing.
(i tried with the GA0039.BIO and with another flash).
So, i can not recover my BIOS.
What can i do now?
Is there any other tricky method to fix this?
Thanks for your help.
Alex.
Stephen
Valued Contributor I
Unplug everything attached to the motherboard only things to remain attached should be
Power Supply
1 Memory Stick in the first memory slot closest/next to the CPU
Keyboard & Mouse
(Recommended) use Integrated Graphics Output or (Optional) attach your GFX card if you prefer
Plug USB to a port on the motherboard preferably a USB 2.0
Remove the BIOS jumper then run recovery.
Let us know if this helps, so it can be used to help others with same problem
Community Manager
So, what i tried is to unplug all sata.
I tried to boot without RAM, i got my 3 beeps, so that was a good thing.
I have no GFX.
I went again for recovery, but still nothing.
Actually, that what i thought.
Desperately, after 15 minutes, i shutted down, plugged again the Jumper (into config mode : 2-3) and it worked.
i had my BIOS back.
So, during the recover, there is no reboot or any signal.
Well, Things solvec.
For others, even if your PC does not reboot, give a try by rpelacing your Jumper back to test.
Thanks for your help stephen.
Alex.
