Community
cancel
Showing results for
Search instead for
Did you mean:
Highlighted
Community Manager
Can't get DG41TX to 1333/1066 Mhz
Hi, can anyone help me with this issue?
I have a DG41TX that is working with the following frequencies (according to cpu-z 64)
CPU:
Bus Speed: 199.5Mhz
Rated FSB: 798 Mhz
Memory:
DRAM frequency: 399Mhz
I have a 4Gb and a 2Gb ddr3 memory modules, both 1333Mhz that I can't get to work on that frequency. CPU-z shows that the frequencies on both slots are 667Mhz (max bandwidth) and on the timings table the frequencies are from 457Mhz to 685Mhz. Does anyone know how to increase these rates?
Kurt
Highlighted
Honored Contributor I
You may have a Mfg. conflict , best pratice is to use same size and type of ram modules .
Highlighted
Community Manager
I have just these two, I don't have other memories or how to change.
Highlighted
If you have two different speeds of Ram by default , It will run at the lower speed , Save your $$$ until you can get the right Ram . I know it is hard out there I always short on $$$ Myself.
