Intel® Desktop Boards
Peer-to-peer support only
This community is designed for sharing of public information. Please do not share Intel or third-party confidential information here.
11461 Discussions
Can't recover BIOS--HELP Please
GLand3
Ihave a DX58OG and I can't boot computer past POST.
The problem began with a failing Raid0 volume. So I changed from raid in the BIOS. I think that while I was in the BIOS, the PCI band limit got changed to 256 from 64. Now I can't boot past POST and can't get into the BIOS to reset to factory default. I've done everything that was suggesting in the manual. I've recovered the most recent BIOS using the CDROM method. I've done many combinations of moving the cmos pin from 1-2 to 2-3 and off. Nothing seems to work. At first, my mouse wasn't lighting up. Now, it does. I attempted to reflash the BIOS via flash drive, but the BIOS doesn't seem to recognize it. I've tried both fat, and fat32 formats. The BIOS on the flash is an earlier version so I am not sure if that's the problem.
Silvia_L_Intel1
Hello Gland, thanks for joining the Intel community.
These are some troubleshooting steps you can follow for this kind of behavior:
If you have access to another system, please check the following link
http://www.intel.com/support/motherboards/desktop/sb/CS-029511.htm Desktop Boards — No Boot Troubleshooting Wizard
http://www.intel.com/support/motherboards/desktop/sb/cs-010254.htm Desktop Boards — Troubleshooting System No Boot Issues
