Community
cancel
Showing results for
Search instead for
Did you mean:
Highlighted
Can´t recovery bios on DZ68DB
I was about to install windows from USB. So I enabled the UEFI boot and USB first check boot, but I´m not sure if the legacy boot was or not enable. And I can´t remember the BIOS version.
When I restarted the computer there is no screen, my keyboard have some led lights but it´s only blink when I turn on the computer then become off, I try F2 but nothing happens. I already tried to clear cmos (jumper 2-3 and removing the battery), but nothing change. I tried to recovery bios from Pendrive, but it´s look like that the USB ports are not inicialized.
Is there anything that I can try? Because I use the computer only for work and don´t need any upgrade.
Thanks in advance.
Tags (3)
Highlighted
Did you follow the instructions in the other post?
Doc
Highlighted
Thank you again @AlHill !
Not yet. I couldn't find the post that you said me to try.
Highlighted
Super User Retired Employee
I am limiting my responses to the OP's other conversation...
