Intel® Desktop Boards
Peer-to-peer support only
This community is designed for sharing of public information. Please do not share Intel or third-party confidential information here.
11463 Discussions
Can't update BIOS DH61BE - Where to download older versions?
RJay0
Only the latest bios is available for download for this board. How am I supposed to update from an older bios? I'm on 32 and need to get to 48 before I go to 120. Using the latest bios just gets me a "Legacy BIOS unsupported" message. Why aren't any other BIOS downloads available? Can anyone help? This bios is so old I can't use a 3rd gen chip.
AlHill
All of the bios files can be found, or at lease used to be found, here.
https://downloadcenter.intel.com/download/23393/BIOS-Update-BEH6110H-86A-?product=51856
Where they are now, I cannot say. Perhaps @n.scott.pearson​  can help.
And, you will want to review this thread:
https://forums.intel.com/s/question/0D50P00004HIiQ1SAL/unable-to-update-bios-past-0035-dh61cr
Doc
RJay0
I found the bios finally hosted elsewhere. I followed the intel guide which didn't work.
BIOS 0048 Flash - All good
BIOS 0099 Flash - Flash went okay, no sata boot
Then I flashed directly to 0120 and it failed
At that point I only got a logo. I tried recovery jumper multiple times but only get a black screen and fan spin.
I then tried switching the jumper to 1 and 2 and managed to get into the bios. It says I'm on 0099 and Intel Management engine is 0.0.0.0
I set it to automatically prompt me to go into the bios. Switching back to regular jumper, I now have access to the bios and even flash. If I try to flash the 0099 bios it freezes. I tried 0109 and it started flashing and then failed at Intel Management Engine. I'm trying another USB stick
n_scott_pearson
Super User Retired Employee
It looks like they pulled down the links for the other BIOS versions. I will ping them and see what's going on. At the very least, you need BIOS 48, 99 and 120.
RJay0
As above, I tried that combination and now have a brick :(. Will try some more USB sticks but not liking my chances. Doing a long format with Fat32 and default allocation size in Win 10. Should I be trying to recover with 99 or 48?
n_scott_pearson
Did you use the BIOS Recovery method? You should have for the BIOS 48 and BIOS 99 installs. If BIOS Recovery will even work, I would try recovering to 99 and then 120.
RJay0
No I used F7 for all of them. BIOS recovery has never worked even with before I flashed anything. The PC turns on and posts. Keyboard and mouse lit up but nothing on screen.
n_scott_pearson
See my notes on things to do to get BIOS Recovery to work in this conversation: https://forums.intel.com/s/question/0D50P0000490FZOSA2/pb-bios-0099-carte-mre-dh61ww.
