Community
cancel
Showing results for
Search instead for
Did you mean:
Community Manager
Chipset Driver Download for DQ965GF Not Valid Application
Jump to solution
I have a DQ965GF board system, but no chipset device drivers. I downloaded INF_allOS_9.1.2.1008_PV.exe which should cover this mainboard. When I double clicked on the file, got an error message "is not a valid WIn32 application. Tried downloading again and trying to run on another machine, but still same error. Any suggestions?
Thanks, Steve
Tags (1)
Community Manager
Hello sfabisze,
I understand that the chipset driver that you downloaded for the Intel(R) Desktop Board DQ965GF is not installing properly.
In regards to your inquire, the driver that you are using may be corrupted, I will provide you with 2 versions below, please try them both on your system to check if one will install.
http://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&ProdId=816&DwnldID=20775&ProductFamily=Chipse... http://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&ProdId=816&DwnldID=20775&ProductFamily=Chipse...
http://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&ProdId=816&DwnldID=20019&ProductFamily=Chipse... http://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&ProdId=816&DwnldID=20019&ProductFamily=Chipse...
Regards.
PV
Community Manager
Hello sfabisze,
Regards.
PV
