Hi guys
I have a problem whit intel desktop board that have b0other me a few times in the past, when I reset the cmos and reconfigure it, I can save my setting but the gonna be erase if I cut the power, its seems that the battery is failing but even whit anew battery still is the same problem. I f I cut the power whe the pc is of the cmos los its configurarion. is there any fix? or it it time to replace the board
thanks in advance.
It seems to be a motherboard problem but if there is a BIOS issue, you could try running BIOS recovery: File name: https://downloadcenter.intel.com/downloads/eula/19845/BIOS-Update-IDG4510H-86A-?httpDown=http://down... ID0135.BIO
Instructions for BIOS recovery available below:
http://www.intel.com/support/motherboards/desktop/sb/CS-023360.htm http://www.intel.com/support/motherboards/desktop/sb/CS-023360.htm
Allan.
Id did that fully recovered but still there is something that don't allow the setting to be saved properly. I love this board is perfect for me but this issue would let me no choice. also I Checked the pins inside the battery holder sometimes the are bent too deep inside that's don't le the battery make full contact. anyway thanks I will deal whit the issue I already took everything out and put it back thogeter. thanks
