Intel® Desktop Boards
Peer-to-peer support only
Welcome to the Intel Community. If you get an answer you like, please mark it as an Accepted Solution to help others. Thank you!
Code 31 Bios
StevenU1
Hola tengo una motherboard Intel extreme DZ77RE-75K, y tengo un problema al encenderla no da imagen y aparece el código 31 eh estado esperando mucho tiempo y sigue sin dar imagen alguna solución?
n_scott_pearson
Super User Retired Employee
Per Table 44 in the board's Technical Product Specification, POST Code 0x31 is an indication that the BIOS has entered its crisis recovery processing. Usually, this POST Code is followed by a display of another POST Code that indicates the type of crisis encountered.
Hhmmm, are you able to capture a video of the POST Code display from power on up until this point?
