Intel® Desktop Boards
Peer-to-peer support only
This community is designed for sharing of public information. Please do not share Intel or third-party confidential information here.
11460 Discussions
Compatibility of win 10 pro 64 bit
SBhat14
i am using intel DH61WW..board...will it support windows 10 pro 64 bit??
AlHill
No, Windows 10 is not supported on this desktop board.
Now, that does not mean that W10 will not run. It will.
Provide your complete processor model number for more information. And, if you have an add-on graphics card, you are better off than you might expect.
Doc
AlHill
Doc
SBhat14
AlHill
That is correct - there are no Windows 10 drivers because WINDOWS 10 IS NOT SUPPORTED.
https://www.intel.com/content/dam/support/us/en/documents/boardsandkits/desktop-boards/desktop-board... https://www.intel.com/content/dam/support/us/en/documents/boardsandkits/desktop-boards/desktop-board...
Any drivers available are part of the Windows 10 install. Just Install Windows 10, noting that there is NO SUPPORT.
Then, go to nvidia.com and get the windows 10 driver for your graphics card.
You should have little trouble.
Doc
SBhat14
i got a cd with the desktop board.will this ok?
n_scott_pearson
Super User Retired Employee
No, you don't need that CD. All you need it the Windows 10 install media (DVD or USB key).
SBhat14
i already owned the key as well as usb 3.0 bootable drive which includes win 10 pro 64 bit.full version.but only the problem is driver compatibility .for this particular board intel realesed max win 8.1 driver..
n_scott_pearson
You are not paying attention! You were just told that you don't need any additional drivers.
Windows 10 has all the drivers that you need built in. Just install it.
SBhat14
you also told me this board dosent support 10.as intel not released win 10 driver for this board...but windows 10 built in all driver such network..lan chipset like which is mandatory?
n_scott_pearson
That is correct; there is no support, but Microsoft provides compatibility drivers to support legacy boards such as this. They don't yield optimal performance, but they do work for the most part. You do need to understand, however, that, without support, if something doesn't work, you have no recourse.
SBhat14
ok..so where i will get compatibility drivers?
n_scott_pearson
We told you already; they are on the Windows 10 installation media. Just install Windows 10.
SBhat14
ok..so need to download and install any driver from anywhere?..just do windows install and that all..all mandatory driver will came automatically?
SBhat14
sorry i just wanted to say no need to downlaod and install any driver from anywhere?
n_scott_pearson
Correct. All necessary drivers are either already on the Windows 10 installation media or will be downloaded from Windows Update as part of the Windows 10 installation process.
Once the Windows 10 installation process has completed, a quick check in Device Manager will tell you if any drivers are missing.
SBhat14
ok if found all drivers are there,then there are no problem..but if found any one missing then what can i do?
n_scott_pearson
Well, if that happens, there is nothing you can do about it (there simply are no alternative drivers). I wouldn't worry about this, however, it shouldn't happen. The WW board does not have any fancy hardware that might require additional drivers.
One additional recommendation: After Windows 10 is installed, download the very latest GeForce driver package for Windows 10 from NVIDIA's web site and install it.
SBhat14
ok..but geoforce driver cd already came with the package.so that will not work on 10?currently i am using this cd on my win 7 64 bit system.
n_scott_pearson
No, don't use the GeForce CD. It has very old drivers on it. Download the latest from the web and install it.
SBhat14
so this is same rule for all dektop and laptop?.i mean windows 10 contents all drivers itself..?
n_scott_pearson
For systems that are this old and have no direct Windows 10 support, yes, it is the same.
Look, you are wasting my time as well as yours. Go install Windows 10 and get it over with.
