Intel® Desktop Boards
Peer-to-peer support only
Welcome to the Intel Community. If you get an answer you like, please mark it as an Accepted Solution to help others. Thank you!
11358 Discussions
Compatibility problem
MCron1
My parents have Intel D945GCCR motherboard, and I've just found them a replacement e3400 CPU. Problem is, it seems to be stuck on x6 multiplier and working only at 1200 MHz.
What's the catch?
MCron1
It shouldn't be. It was bought in a regular store, and worked at 2.6 MHz with x13 before. I will go look at that software you recommended, and get back later with results..
MCron1
MCron1
Oh my mistake. The old one was series 2xxx, released same time as the MoBo (~2006). Since it's too old, I had to replace it with newer one - E3400 (released in 2010)
Intel BIOS does not support it. Latest BIOS version is from 2008.
So it seems it can't work on this MB. Intel motherboard, Intel CPU, both 775 but not compatible. Lame.
Thanx anyway for help.
