Community
cancel
Showing results for
Search instead for
Did you mean:
Highlighted
Community Manager
Correct Intel chipset device software?
I have a DH61WW (confirmed with dxdiag and CPU-Z) board and I found a chipset device software for this board at here: http://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=20821&ProdId=3325&lang=eng&OSVersion=... http://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=20821&ProdId=3325&lang=eng&OSVersion=...
My board is listed on the download page.
But when I downloaded it and looked at the readme and it said that the software is intended for the Intel 7 series but isn't the DH61WW an Intel 6 series?
I am a bit confused now. Is this the wrong software for my chipset?
Thanks in advance,
Amaranty
Highlighted
New Contributor II
Note that it says "Target," which must mean that's what's been enhanced in this release (i.e. support for the new chipsets). It definitely also supports older ones though, like yours, as you found on the download page but which you'll also see when viewing the "All" directory in the download.
