Intel® Desktop Boards
Peer-to-peer support only
11478 Discussions
Correct Z390 Chipset Driver
MWils29
Currently I have 10.1.17968.8131 installed.
MB Manufacturer (MSI)'s website suggest newer version (10.1.18228.8176) is available:
https://www.msi.com/Motherboard/support/Z390-A-PRO#down-driver&Win10%2064
This won't install for me.
Official Intel page for the Chipset:
https://downloadcenter.intel.com/product/133293/Intel-Z390-Chipset
Does not list a chipset driver
The latest chipset driver on the Intel site does seem to be 10.1.17968.8131:
https://downloadcenter.intel.com/download/29227/Chipset-INF-Utility - BUT this does not specifically list the Intel Z390 Chipset
Gigabytle (not my MF) have a version 10.1.18243.8188 - released
2020/03/10
Why does the latest Intel chipset driver not support Z390?
I have emailed my MB manufacturer support but they state:
"Information on the Intel’s side isn’t exactly clear as well. Inside the installer it says driver package is covering 300 series chipset without any exclusions but on the web page, Z390 is not listed in the supported chipset models."
AlHill
There is no chipset "driver". The INF is just a definition file that can be applied.
If the MSI chipset inf for your board will not install, contact MSI for support.
Doc
MWils29
I did contact them, before posting here. They stated: ""Information on the Intel’s side isn’t exactly clear as well. Inside the installer it says driver package is covering 300 series chipset without any exclusions but on the web page, Z390 is not listed in the supported chipset models."
Both the downloads from MSI and from Intel for 10.1.18228.8176 contain a file called SetupChipset.exe - with identical MD5 sum - so presumably the same file.
This fails to run on my machine, regardless of the source MSI or Intel.
Matthew
AlHill
With the inf extracted as you have done, try running "SetupChipset /overall"
Doc
MWils29
Same error as before "The feature you are trying to use is on a network resource that is unavailable".
Thanks for your help!
AlHill
You have a problem with Windows.
You can try the solution here:
https://www.windowscentral.com/how-fix-network-resource-unavailable-install-error-windows-10
The above link is provided for your convenience. And, there are lots of "solutiins" on the web for this windows error.
Doc
MWils29
AlHill
So, you have it installed?
Doc
MWils29
Yup - once as I ran the troubleshooter as suggested in the windows central article you sent, the new version installed fine, without the error!
Thanks for all your help.
AlHill
Super. Glad it worked. That network resource error has been around forever.
Doc
