Community
cancel
Showing results for
Search instead for
Did you mean:
BShel1
Corrupted BIOS screen/POST code 40 after memory upgrade
Hey everyone,
A couple days ago, I upgraded my memory from a kit of 16gb (4x4) G.Skill DDR3-1600 to a set of 32gb (4x8) Kingston HyperX DDR3-2400 and got some strange graphical corruption on my board splash screen (see below), plus a code "40" after booting into the OS under most circumstances. Apart from these two symptoms, I can't perceive any kind of performance issue or instability. The system does recognize all 32gb of memory, however CPU-Z has a blank memory timing tab.
System:
i7-3930k
32gb DDR3-2400
DX79SR
Windows 8 Home
Here's what I've tried so far:
Reinstalled the old memory: no change in POST screens. Didn't boot to Windows to see if code appeared.
Reinstalling the latest BIOS/downgrading to previous version: no change.
Changed the overclock presets: POST screen was still screwy, but the code 40 DID NOT appear on the "Default" overclock preset. 1.00 and 1.25 presets still throw 40.
Manually selecting board memory 1666mhz/Kingston 2133mhz XMP profile: System wouldn't complete POST.
BShel1
Have an update: even under the default BIOS settings, the board threw a code 40. I then shut off the Turbo Boost feature to run the Processor Diagnostic Tool (which passed 100%) and the POST code went away.
