Intel® Desktop Boards
Peer-to-peer support only
This community is designed for sharing of public information. Please do not share Intel or third-party confidential information here.
11462 Discussions
D201GLY2 XP installation problem
MMann11
I have a D201GLY2 motherboard that I am bringing back into service. I used to have XP Pro installed on it and want to reinstall it but it won' install. I have the latest bios and have tried every configuration possible in the bios but it still refuses to install. I have been able to install Windows 7 (which Intel says won't work but it runs fine, just very slow, where XP is much snappier on this board). My thinking is that it is a sata driver problem but I can't find the sata driver for this board on the Intel site as the D201GLY2 board as it has a SiS662* Graphics and Memory Controller (Northbridge) and a SiS964* I/O Controller (Southbridge). I used to run XP with SATA disabled in the bios but that won't work now. Probably something to do with the updated bios.
Anybody know how to get XP re-installed.
Allan_J_Intel1
Thanks for joining the Desktop Board community.
Does this problem occur with an earlier BIOS version?
You could try to downgrade BIOS version with BIOS recovery method, see instructions below:
http://downloadcenter.intel.com/confirm.aspx?httpDown=http://downloadmirror.intel.com/14747/eng/LY01... LY0133P.BIO
Instructions for BIOS recovery available below:
http://www.intel.com/support/motherboards/desktop/sb/CS-023360.htm Desktop Boards — Instructions for Recovery BIOS Update
Allan.
MMann11
Thanks Allen
Yes I did downgrade the Bios and I did get XP to install but I am having the problem of XP freezing at the boot screen. I ran safe mode bootlogger and here is the part of the ntbtlog.txt file where XP freezes at the "Did not load driver ACPI Uniprocessor PC." Have googled the Did not load driver ACPI Uniprocessor PC but haven't found any solutions.
Mick
Loaded driver sr.sys
Loaded driver KSecDD.sys
Loaded driver Ntfs.sys
Loaded driver NDIS.sys
Loaded driver Mup.sys
Did not load driver Audio Codecs
Did not load driver Legacy Audio Drivers
Did not load driver Media Control Devices
Did not load driver Legacy Video Capture Devices
