Intel® Desktop Boards
Peer-to-peer support only
Welcome to the Intel Community. If you get an answer you like, please mark it as an Accepted Solution to help others. Thank you!
11358 Discussions
D2500CC PS/2 and serial
BArd
  1. On my board the PS/2 ports does not work at all, seems totally dead.
  2. During the boot process the serial pins get high twice, first for a very short time and the second time is nearly one second before it goes down to low.
Can this be solved with a BIOS update? I have version 0039 which is the latest to this date.
regards
Buck
Jose_H_Intel1
Hello Buck,
In this case the first recommendation is to make sure you are using a power supply that will provide the proper (wattage) power requirements for your needs. If you test a second power supply and the issue persists you may consider resetting and updating the BIOS.
Otherwise you may contact your local Intel® support team.
http://www.intel.com/p/en_US/support/contactsupport http://www.intel.com/p/en_US/support/contactsupport
