Community
cancel
Showing results for
Search instead for
Did you mean:
Community Manager
D2700DC Bios power option not functioning
I have a couple D2700DC motherboards that I'm trying to get into service. The application requires that the unit returns to 'Power ON' after power failure. The motherboard doesn't follow the bios settings when power is returned.
I have tried:
- each new bios as it becomes available.
- creating my own bios image with the Integrator Toolkit (wherein I set the 'After Power Failure' flag to the mode I want)
Each attempt ends without success. It appears that it just doesn't work.
Can someone nudge the devs and have them test/repair this?
Much appreciated.
Kevin
Community Manager
Clear the CMOS battery for 30 minutes. Reboot the system and in the BIOS setup utility, press to restore BIOS to defaults. Proceed with a BIOS recovery test. Latest BIOS version can be downloaded from the following web site:
Download Center
Instructions can be found at this link:
http://www.intel.com/support/motherboards/desktop/sb/cs-022312.htm Desktop Boards — BIOS update instructions
Ensure you have followed a clean installation of the Operating System using the latest drivers from our website.
If the issue persists, replace the motherboards under warranty.
