Intel® Desktop Boards
Peer-to-peer support only
Welcome to the Intel Community. If you get an answer you like, please mark it as an Accepted Solution to help others. Thank you!
11360 Discussions
D2700DC board keeps crashing for no aparent reason...
Community Manager
Hello everyone.
This is my relatively new mediaplayer machine.
It is based on an Intel D2700DC mini-ITX board with intergrated dual-core Atom processor @ 2.1GHz, and HDMI out. 4GB DDR3 RAM, and 40GB Intel SSD. Windows 7 Ultimate 32-bit. All media is played from mapped network drives on the server in the other room of the house.
Runs fine for a few days, then dies for no apparent reason.
I leave the machine on 24/7, just turn the projector off.
I have the AUTOMATICALLY RESTART option UNTICKED, so that when the machine falls over, I SHOULD get a BSOD, but I don't - the screen just dies(stays blue with no text on it), nothing responds, and I have to reboot.
The only consolation in all this, is that with the SSD, it reboots in about 10 seconds, which is nice, but does not fix the problem.
I downloaded and ran bluescreenview, and attached is the log it generated.
Does not seem to be any one common thing causing the issue - one day it is hal.dll, then next is is the kernel, the next it is the filesystem driver...
Can anyone help me work out what is going on?
Dump File : 011213-7566-01.dmp
Crash Time : 12/01/2013 2:39:46 a.m.
Bug Check String : KERNEL_MODE_EXCEPTION_NOT_HANDLED
Bug Check Code : 0x1000008e
Parameter 1 : 0xc000001d
Parameter 2 : 0x81a78b17
Parameter 3 : 0x9f81bbb4
Parameter 4 : 0x00000000
Caused By Driver : hal.dll
Caused By Address : hal.dll+5ba9
File Description : Hardware Abstraction Layer DLL
Product Name : Microsoft® Windows® Operating System
Company : Microsoft Corporation
File Version : 6.1.7600.16385 (win7_rtm.090713-1255)
Processor : 32-bit
Crash Address : ntoskrnl.exe+26eb17
Stack Address 1 : ntoskrnl.exe+6d403
Stack Address 2 : ntoskrnl.exe+6d0e1
Stack Address 3 : ntoskrnl.exe+2316ed
Computer Name :
Full Path : C:\Windows\Minidump\011213-7566-01.dmp
Processors Count : 4
Major Version : 15
Minor Version : 7600
Dump File Size : 147,474
Dump File : 010813-6957-01.dmp
Crash Time : 8/01/2013 8:14:50 p.m.
Bug Check String : PAGE_FAULT_IN_NONPAGED_AREA
Bug Check Code : 0x10000050
Parameter 1 : 0x8223f392
Parameter 2 : 0x00000008
Parameter 3 : 0x8223f392
Caused By Driver : win32k.sys
Caused By Address : win32k.sys+9fbb4
File Description : Multi-User Win32 Driver
Processor : 32-bit
Crash Address :
Stack Address 1 : ntoskrnl.exe+4342a
Stack Address 2 :
Stack Address 3 :
Computer Name :
Full Path : C:\Windows\Minidump\010813-6957-01.dmp
Major Version : 15
Dump File Size : 147,026
Dump File : 010313-7020-01.dmp
Crash Time : 3/01/2013 10:02:36 p.m.
Bug Check String : BAD_POOL_HEADER
Bug Check Code : 0x00000019
Parameter 1 : 0x00000022
Parameter 2 : 0x00020000
Parameter 3 : 0x00000000
Caused By Driver : ntoskrnl.exe
Caused By Address : ntoskrnl.exe+9dd89
File Description : NT Kernel & System
Processor : 32-bit
Crash Address : ntoskrnl.exe+9dd89
Stack Address 1 : ntoskrnl.exe+11f144
Stack Address 2 : ntoskrnl.exe+68c4d
Stack Address 3 : Npfs.SYS+a164
Computer Name :
Full Path : C:\Windows\Minidump\010313-7020-01.dmp
Major Version : 15
Dump File Size : 146,706
I replaced the PSU, thinking it could be that, having had that suggested to me by others, but after another five days on this PSU, the system crashed again with another BSOD:
Dump File : 011713-6973-01.dmp
Crash Time : 17/01/2013 7:19:19 a.m.
Bug Check String : IRQL_NOT_LESS_OR_EQUAL
Bug Check Code : 0x1000000a
Parameter 1 : 0x8cd830b4
Parameter 2 : 0x00000002
Parameter 3 : 0x00000001
Parameter 4 : 0x82885c43
Caused By Address : ntoskrnl.exe+6ec43
Processor : 32-bit
Crash Address : ntoskrnl.exe+6ec43
Stack Address 1 : ntoskrnl.exe+7198f
Stack Address 2 : ntoskrnl.exe+88f38
Stack Address 3 : ntoskrnl.exe+98768
Computer Name :
Full Path : C:\Windows\Minidump\011713-6973-01.dmp<p...
Community Manager
...and another crash now - that is two today so far.
This time, while I was watching something.
Dump File : 011713-7550-01.dmp
Crash Time : 17/01/2013 12:24:31 p.m.
Bug Check String :
Bug Check Code : 0x00000116
Parameter 1 : 0x84fcf510
Parameter 2 : 0x8fc1c0df
Parameter 4 : 0x00000002
Caused By Driver : igdkmd32.sys
Caused By Address : igdkmd32.sys+20df
File Description : Intel (R) WDDM Kernel mode driver
Product Name : Intel Graphics Accelerator Drivers for Windows 7(R)
Company : Intel Corporation
File Version : 8.14.8.1083 built by: WinDDK
Processor : 32-bit
Crash Address : ntoskrnl.exe+dcd10
Stack Address 1 : dxgkrnl.sys+8c92c
Stack Address 2 : dxgkrnl.sys+8d74b
Stack Address 3 : dxgmms1.sys+692c
Computer Name :
Full Path : C:\Windows\Minidump\011713-7550-01.dmp
Major Version : 15
Dump File Size : 171,978
This time, it seemed to be the video driver.
I really don't think HDMI is worth it.
Yes, it is a better picture then VGA, but the old mediaplayer, also running an Intel Atom board but without HDMI, ran for months on end without ever crashing. I don't think much of Win7 and HDMI as a mediaplayer.
I might just install good old XP and see what happens. Will have to be on a standard HDD though, which will make boot-up slower, but if it stays up and running longer then Win7 seems to be doing, so much the better.
