I use a D2700DC w/o HDD and want to boot from a USB memory stick. (I think that) all settings are made in the BIOS to boot from USB,
but on the screen the typical message "... no bootable device found ..." appears.
If I select the "boot options" menu with after a restart, I can choose to boot from USB, and it will work without a problem. But after a
restart, the system will not automatically boot from the USB memory stick.
In the BIOS the following settings are made:
Legacy USB support enabled
Boot from USB enabled
Boot first from USB enabled
All BIOS optimization disabled
Product Code: BOXD2700DC
Version # : G32420-602
S/N: BQDC21700234
Date of manufacture: 27 APR 12
What is the problem with the settings I've done? The BIOS version is the originally one (no update till now).
Thanks for your help,
Tobias
Hello Tobias,
In this case you may probably want to update the BIOS incrementally.
BIOS update instructions
http://www.intel.com/support/motherboards/desktop/sb/cs-022312.htm http://www.intel.com/support/motherboards/desktop/sb/cs-022312.htm
Hello Tobias,
