In our company we are using d2700mud atom boards with windows xp 32 bit operating systems. They working Ok, excluding one thing. You cannot unplug the monitor. If you do that, the pc will start without it, but the next time you turn it on with monitor it wont work. We have to power it up in rescue mode then and reinstal graphic drivers. Sometimes the pc crashes without monitor too.
Longstory short, if you unplug the monitor you will have to reinstall the drivers. Same thing every time.
I would really aprichiate a solution to this flustrating situation. Our pcs cant run headless.
lp, sorry to hear you are having problems with your board, but please allow me to help you.
Would you please connect another monitor and test the board again?
What kind of graphic connection are you using? VGA/DVI?
Make sure you are using the correct graphic driver https://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=21902&lang=eng&OSVersion=Windows%20X... Download Center
Also, check if you have the latest BIOS version installed, is not please download it from the following link https://downloadcenter.intel.com/SearchResult.aspx?lang=eng&keyword=Intel%20Desktop%20Board%20d2700m... Download Center
This worked. Thank you.
False alarm. Now when we power up the PC with monitor connected, he stops working right after windows loads. The pc works though, but we cant use the monitor.
Please suggest some more solutions.
How many monitors do you want to connect on this motherboard? Are you trying dual display?
Did you update the BIOS or the graphic drivers?
