I want to install two 6TB HDDs on the D510MO.
Does someone know, if this will be able to?
Thank you for ideas.
Hi Elrond,
It is necessary to have UEFI boot option in the BIOS to use Hard Disk Drives with 2TB or more. Your board is old and this feature is not available.
Unified Extensible Firmware Interface
https://en.wikipedia.org/wiki/Unified_Extensible_Firmware_Interface Unified Extensible Firmware Interface - Wikipedia, the free encyclopedia
Mike C
NM10 chipset SATA controller do not support 2Tb+ drives, neither available drivers for it.
Intel included UEFI option in the BIOS since 7 chipset series.
Mike C
Hello mikec_intel,
hello JFFulcrum,
thank you for reply. I want to boot the OS DSM from Synology by using XPEnoboot from usb-stick. Actually i do this and i have two 2.0TB WD RED for data.
Someone wrote to me that i should not encounter any problems. This guy is running two 3.0TB WD RED disks at his M510MO at the moment. And there will not be any limitation regarding size after the 2TiB 32-bit sector addressing.
So do you think that i will have any problems with 6.0TB disks.
Than you for reply.
Elrond
Chipset and MB bios had no support for LBA-48, although system can see 2 TB size from 6 TB HDDs or see something else (like some MBs only), depends of BIOS.
So i have to install a special pci or mini-pci-express sata-controller for my disks?
Yes, but PCI is limited to 133 M/s, so performance will be limited too.
Thanks, so it will make more sense for me to by a real NAS-system just like Synology or something else.
I bought two 6TB HDD and installed them. The BIOS saw them correctly and so i booted the system from USB-Stick. The DSM saw the the two HDDs too. 10,82 TB together. 3,2 TB are used now.
I will inform you.
