Community
cancel
Showing results for
Search instead for
Did you mean:
Highlighted
Community Manager
D525MW COMM (serail) port doesn't work in windows 7
My D525MW COMM port works properly with windows xp but when I install windows 7 on this motherboard, the COMM port doesn't work at all. Even if I add the second serial port, it also doesn't work. I have test on 2 different motherboard and see this problem on both of them.
Does any one has the same problem? Any idea?
Tags (1)
Highlighted
I am sorry to hear that have had issues with your Intel motherboard.
Is your operating system Win7 32 bit or 64 bit?
Allan.
Highlighted
Community Manager
Dear Allan,
I have windows 7-32 bit.
Highlighted
Community Manager
Dear Allan,
I tested both suggested ways. Now my windows 7 has sp1 and I installed the last version of chipset utility but none of them didn't work.
Any idea?
P.S: I have installed some devices same as check scanner, printer and ... to all of it's USB port. Can this issue causes some problems?
Highlighted
The motherboard was designed to work under Windows 7 32 bit operating system; I recommend re installing the operating system but make sure the service pack is included on the disk.
Allan.
Highlighted
Community Manager
Dear Allen
Thanks so much. With installing another windows 7, my problem solved.
