Community
cancel
Showing results for
Search instead for
Did you mean:
Highlighted
Community Manager
D525MW USB header/port for flash card / SSD?
I am wondering if I could use a USB header for flash card/SSD (marked USB Flash on the motherboard) as a regular internal USB header.
What I want to do is just plugging in this (below link) kind of a USB motherboard header adapter and getting 2 more usual USB ports for putting some USB devices (memory card or SATA/IDE adapter, etc) inside the box.
http://www.newegg.ca/Product/Product.aspx?Item=N82E16812200474CVF&cm_re=usb_header-_-12-200-474CVF-_... http://www.newegg.ca/Product/Product.aspx?Item=N82E16812200474CVF&cm_re=usb_header-_-12-200-474CVF-_...
Has anyone tried this before? If I could only use 1 USB device with this port, I might go with this cable.
http://www.newegg.ca/Product/Product.aspx?Item=N82E16812200476CVF&cm_re=usb_header-_-12-200-476CVF-_... http://www.newegg.ca/Product/Product.aspx?Item=N82E16812200476CVF&cm_re=usb_header-_-12-200-476CVF-_...
You advice would be very appreciated.
Thanks!
Bill
