Community
cancel
Showing results for
Search instead for
Did you mean:
Community Manager
D945GNT Headphone socket not working under Windows 7
Jump to solution
The headphone socket on my Intel D945GNT system board does not seem to work under Windows 7 Pro 64 bit.
It worked ok under Windows XP Pro 32 bit.
Should I try installing the IDT audio drivers, even though they aren't listed as Windows 7 compatible?
Kevin_M_Intel
The latest drivers we have for this motherboard are for Windows Vista. You can try installing the driver on Windows 7 but we cannot guarantee it will work but as I said before, you can give it a try.
Kevin M
Kevin_M_Intel
Kevin M
Community Manager
That seems to work fine.
Many thanks.
