Trying to update Bios of Motherboard - INTEL D946GZIS
Current revision: TS94610J.86A.0025.2006.0703.1026
Updating to revision TS94610J.86A.0087.2007.1107.1049
Preparing image for recovery firmware ...[done]
Preparing image for main firmware ...[done]
Preparing image for logos ...[done]
Preparing image for supplemental recovery area ... [done]
Flashing image for recovery firmware ... [failed!]
Flash update failed!
Technical information: (0x80000002, 1278)
Can some one help. Why the bios is not getting updated.
Hello Hardeep, thanks for joining the Intel Community.
I was checking the BIOS versions available for this motherboard on the download center, and there are 15 different files from the previous version you had and the one you just installed.
I would like to tell you that going straight to the latest version shouldn't be a problem, technically speaking. However based on experience, there is always chance.
In your case, I think that going straight to the latest BIOS version was not the best for your system.
I would recommend checking the BIOS Update Release Notes on this URL. You will be able to see the fixes and features included on each version.
http://downloadmirror.intel.com/14847/eng/TS_0087_ReleaseNotes.pdf http://downloadmirror.intel.com/14847/eng/TS_0087_ReleaseNotes.pdf
Please install these BIOS versions one by one
BIOS Version 0034 https://downloadcenter.intel.com/download/11197/BIOS-Update-TS94610J-86A- Intel® Download Center
BIOS Version 0047 https://downloadcenter.intel.com/download/11734/BIOS-Update-TS94610J-86A- Intel® Download Center
BIOS Version 0064 https://downloadcenter.intel.com/download/12482/BIOS-Update-TS94610J-86A- Intel® Download Center
BIOS Version 0067 https://downloadcenter.intel.com/download/12591/BIOS-Update-TS94610J-86A- Intel® Download Center
BIOS Version 0080 https://downloadcenter.intel.com/download/13790/BIOS-Update-TS94610J-86A- Intel® Download Center
BIOS Version 0085 https://downloadcenter.intel.com/download/14354/BIOS-Update-TS94610J-86A- Intel® Download Center
BIOS Version 0087 https://downloadcenter.intel.com/download/14847/BIOS-Update-TS94610J-86A- Intel® Download Center
Silvia L
