Intel® Desktop Boards
Peer-to-peer support only
11478 Discussions
D946GZIS motherboard modifications
MNewm4
I have a D946GZIS motherboard and, to the best of my knowledge, it does not support Wake-on-Lan. Is there a way to modify the board to start with Magic Packets?
n_scott_pearson
Super User Retired Employee
According to the TPS for this board, LAN wake capabilities *are* supported in the D946GZIS board. I suggest that you look at the Boot menu in the BIOS for related configuration parameters...
Hope this helps,
MNewm4
Thank you. I will look at the BIOS again as I could not see it. I also looked at the specifications on line and they did not say that WOL was available either. That is why I posted the question.
n_scott_pearson
Oops, they would be in the Power menu, not Boot. I will also add that the TPS, um, 'carefully' said "LAN wake", not "Wake on LAN"...
