Intel® Desktop Boards
Peer-to-peer support only
11479 Discussions
D955XBK CPU with Virtualization?
TBrud
I currently have the Intel D955XBK board with an Intel Pentium D 830 3.0 GHZ 800Mhz bus. I just upgraded from XP to Windows 7 Ultimate 64bit and I'm disappointed to see I cannot run Virtual PC because my CPU lacks Virtualization support. What's the fasted CPU that supports HW Assisted Virtualization for this motherboard??
Troy
Community Manager
From the link below, you will note that the cpu pentium d 830 does not support VT.
http://ark.intel.com/Product.aspx?id=27513&processor=830&spec-codes=SL88S,SL8CM,SL8CN,SL8CP http://ark.intel.com/Product.aspx?id=27513&processor=830&spec-codes=SL88S,SL8CM,SL8CN,SL8CP
Before getting any new CPU, make sure to check if the option to enable VT is found in the bios. It may under security settings.
Then check from the list of compatible CPUs which one supports VT.
http://www.intel.com/support/motherboards/desktop/d955xbk/sb/CS-026574.htm http://www.intel.com/support/motherboards/desktop/d955xbk/sb/CS-026574.htm
All the best,
Kind Regards,
Aryan
PSzmr
Try replacing the CPU... I've recently replaced my 840 CPU with a 965 and VT (which was not available) is now available in the BIOS.
