Intel® Desktop Boards
Peer-to-peer support only
11478 Discussions
DB75EN doesn't work with GTX 460
ААндр2
Hi, I need your help.
I installed the motherboard DB75EN video card GTX 460, but works only integrated graphics processor core i3 2120.
In the BIOS graphics card is not detected.
However when I install the video card GTS 450, everything works.
Thanks for answers/
Community Manager
Hello drew@74:
In regard to your inquiry, the thing is that some video cards are compatible and some other video cards are not.
In those cases what we recommend to do is a BIOS update to the latest version of the motherboard, if the video card still does not work after that is because is not compatible.
Instructions to do a BIOS update using the F7 method:
http://www.intel.com/content/www/us/en/support/boards-and-kits/desktop-boards/000005724.html http://www.intel.com/content/www/us/en/support/boards-and-kits/desktop-boards/000005724.html
And this is the .BIO file that you need to do the update:
https://downloadcenter.intel.com/download/22943/BIOS-Update-ENB7510H-86A-?product=59043 https://downloadcenter.intel.com/download/22943/BIOS-Update-ENB7510H-86A-?product=59043
Also, on the following link you will be able to see some tested peripherals, in there you will see some video cards that were tested by Intel, however, there are video cards that are not listed there but they still work with the board:
http://www.intel.com/content/www/us/en/support/boards-and-kits/desktop-boards/000007777.html http://www.intel.com/content/www/us/en/support/boards-and-kits/desktop-boards/000007777.html
Alberto
ААндр2
Hello, Alberto.
Thanks for answer.
BIOS update to version 0046. This version is the latest. My video card produced by MCI.
Now I want to try different versions of BIOS.
Also, system stand on Windows 10.
Sorry for my bad english.
Community Manager
Hello drew@74:
Perfect, thank you very much for letting us know that information.
No problem, you can go ahead and try those steps, hopefully you will be able to make the video card work, even though it seems a compatibility situation.
Alberto
