Intel® Desktop Boards
Peer-to-peer support only
Welcome to the Intel Community. If you get an answer you like, please mark it as an Accepted Solution to help others. Thank you!
11360 Discussions
DB85FL: BIOS has detected unsuccessful POST attempt(s).
JHuss2
after installing alot of engineering softwares such as matlab and solidworks, this message started to pop out every time i turn on my computer:
bios has detected unsuccessful POST attempt(s) (...) press y to enter setup or N to cancel and to boot with previous settings.
well, it was working fine at the beginning when i press n it restarts and when i press y it goes to bios setup, but after few days my computer started to take alot of time to turn on it was like it keeps restarting every 5 seconds, and when i get this message if i press y it freezes and n it restarts, and if it worked and launched, the resolution would be really bad as if there is no vga detected. i tried formatting and the same thing didnt change but got worse.
my vga is nvidia gtx 670 with 16 gb ram envy hyperx and a db85l intel.
please if anyone knows how to fix it let me know.
thanks.
Jose_H_Intel1
You may remove power and CMOS battery for twenty minutes and/or try a BIOS recovery.
http://www.intel.com/support/motherboards/desktop/sb/CS-023360.htm Desktop Boards — Instructions for Recovery BIOS Update
