Intel® Desktop Boards
Peer-to-peer support only
Welcome to the Intel Community. If you get an answer you like, please mark it as an Accepted Solution to help others. Thank you!
11361 Discussions
DB85FL boot menu not working after BIOS update
CChav1
Hello
I just applied the latest BIOS upgrade available for my DB85FL : https://downloadcenter.intel.com/download/24354/BIOS-Update-FLB8510H-86A- Intel® Download Center, but right after the successful installation, when the computer boots and I press the F10 key in order to access the boot menu, the list appears with a single element listed in it, usually the network card. Even if I try to boot from USB or from a different drive than the default system drive, the list always displays a random single element, but when I access the BIOS, the drive list shows all the connected drives, including the network card and the USB thumb drives. The F10 boot menu used to work flawlessly before the upgrade, so I don't know if I have to do a downgrade on the BIOS version to get the menu to work properly (I don't know if that downgrade is possible). I've tried everything from enabling and disabling different options in the BIOS settings to unplugging the physical drives but nothing seems to work. I use the boot menu option most of the time because I have different operative systems installed in different drives, so it's really important for me to have it working properly.
This is what I have
Intel DB85FL
8 GB RAM DDR3 1333 MHz
1 TB Drive (Win) SATA3
250 GB Drive (Linux) SATA3
250 GB Drive (Mac -iAtkos-) SATA3
DVD RW Drive (SATA)
Thanks in advance.
JBish3
New Contributor II
Before i can give you any advice. Can u tell me , which OS u have in your HDD/SSD efi or legacy ?
CChav1
I use legacy BIOS. The SATA mode is AHCI.
Kevin_M_Intel
If you remember the previous BIOS version that was installed, try downgrading to that version for troubleshooting steps.
CChav1
Is it safe? I'll try it anyway and I'll post the results.
Kevin_M_Intel
You can do that but always try saving the information first before doing changes in the computer.
