Intel® Desktop Boards
Peer-to-peer support only
Welcome to the Intel Community. If you get an answer you like, please mark it as an Accepted Solution to help others. Thank you!
11361 Discussions
DG31GL (Refurb) Issues - 4 beeps
TBoes2
I just picked up an Intel Refurbished DG31GL board off of Newegg to replace a dead MSI board.
With everything installed on the board and when I power up the machine I do not get any video out and during post (I assume it's post) I get 4 short beeps.
I swapped RAM (DDR2 - 800mhz) and even pulled the ram. I get the expected 3 long beeps at that point.
Can anyone give me any suggestions on what the 4 beeps could mean? I do not see any reference to it in the manual.
Thanks!
Silvia_L_Intel1
Hello Tyjbo,
We would like to inform you this motherboard has been discontinued, but the 4 beeps codes for discontinued desktop boards means "Timer not operational" http://www.intel.com/support/motherboards/desktop/sb/cs-010249.htm ttp://www.intel.com/support/motherboards/desktop/sb/cs-010249.htm
So here are our recommendations for this issue:
- Proceed to test the motherboard on a minimal configuration out of the chassis to discard any grounding issue.
-Clear the CMOS battery for 30 minutes and proceed with a BIOS recovery test: http://www.intel.com/support/motherboards/desktop/sb/cs-022312.htm Desktop Boards — BIOS update instruction
-If you continue having the same behavior, feel free to contact your local Intel support group for assistance on replacing your product if it is still under warranty: http://www.intel.com/p/en_US/support/contactsupport?group=processor http://www.intel.com/p/en_US/support/contactsupport?group=process
Regards.
Silvia_L_Intel1
Hello Tyjbo,
Regards.
