Community
cancel
Showing results for
Search instead for
Did you mean:
Community Manager
DG33BU & Speedfan Issues using w7 Ultimate
I recently picked up a desktop pc with the DG33BU mo/bo inside (came with no driver discs), it was running on Vista Home Basic and needed much attention as it was running real slow. After cleaning it up, defragging etc, I got it running pretty smooth and installed Speedfan. This worked well and was reporting quite a few temps which are listed below.
CPU die
Motherboard
System case
HDD
ICH (southbridge)
MCH (northbridge)
Core 0
Core 1
All of the temps were fine, though the ICH & MCH were both above 65C.
I decided to upgrade to W7 Ultimate x64 and once set up was complete, I installed speedfan again but this time it is only reporting on
HDD
Core 0
Core 1
Does anyone know why this has happened and is there a fix for it. I can't understand why under Vista it was reporting so well yet under W7 its only showing 3 temps.
Tags (1)
Community Manager
It's been a week since I posted this, I was hoping someone would have replied by now with an answer or a fix.
