Intel® Desktop Boards
Peer-to-peer support only
This community is designed for sharing of public information. Please do not share Intel or third-party confidential information here.
11461 Discussions
DG33FB - is there a way of using the PCIe x16 slot without disabling the onboard graphics?
Community Manager
I had a thread over here: which was partially answered by Dan_Intel but it's not quite answered my question.
It appears that when a card is installed into the PCIe x 16 slot, it automatically disables the onboard graphics. Is there a way of getting around this so a SAS card can be used without disabling the onboard graphics?
Martin
Community Manager
Thank you for the information. Unfortunately this feature is not supported on this Intel(R) 3 Series Chipset Desktop board.
The Switchable Graphics feature is supported only for certain motherboards with the Intel® Z68 and Z77 Express Chipset.
Community Manager
That's not quite what I mean either.
I don't want to use a graphics card in the PCIe x16 slot, I want to use a SATA/SAS storage card in it. Problem is, when I put the SATA/SAS card into the PCIe x16 slot, it disables the onboard graphics, which results in no video output.
Please tell me if I need to clarify further.
Cheers,
Martin
Community Manager
Hello, the onboard graphics are disabled as the plug an play id from your controller card is similar to the one found on a video card.
In BIOS under the advanced tab ( configuration ) you should have the option to set the graphics preferences, in there set only the onboard.
Also on the security tab you should have an option called expansion card text, please try enabling it, this sometimes allows the cards to be recognized properly.
Regards.
Community Manager
Thanks Victor, I'll try that tonight (in about 5-7 hours).
Martin
