Hi i would like to know how can i install bios update on windows 7x64 for DG33Tl right the Bios version i am currently running is DPP3510J.86A.0293.2007.1002.1519,10/2/2007 if any can help would really appreciate or if one can tell me i should not update? and what other drivers i can update. Thank you
There isn't a Windows 7 Express BIOS update for your motherboard and it would be too risky to use the Vista/Windows XP versions. You'll need to use one of the other methods. The pdf for the last BIOS released for your board has all the changes from the BIOS flashed on your board. Here's the link:
http://downloadmirror.intel.com/17930/eng/DP_0572_ReleaseNotes2.pdf http://downloadmirror.intel.com/17930/eng/DP_0572_ReleaseNotes2.pdf
It's totally up to you to decide whether you need to flash up or not.
