Community
cancel
Showing results for
Search instead for
Did you mean:
Community Manager
DG33TL refuses / fails all BIOS updates
I have recently tried to install a MSI Radeon HD 6670 2GB GDDR3 onto my board. However, after install while it did power on and display the BIOS splash screen, it would lock up at that point. Being able to think of nothing else and receiving no useful suggestions from MSI customer support, I decided to try a BIOS update to see if that might fix the problem.
Problem is, no matter how or which BIOS update I choose to download & install, whether it be the newest one or any inbetween from the revision I currently have. I receive the following:
Current revision: DPP3510J.86A.0326.2008.0227.1102
Updating revision: DPP3510J.86A.0572.2009.0715.2346
Preparing image for Intel(R) Management Engine firmware ... [done]
Preparing image for recovery firmware ... [done]
Preparing image for main firmware ... [failed!] (30608 bytes overflow)
Flash update failed!
Technical information: (0x80000000000000B, 1267)
Depending on the BIOS version I am trying to install, this differs only with (???? bytes overflow). But it literally with EVERY single BIOS version I have downloaded and tried. I have used the .EXE files, I have downloaded Intel Integrator Toolkit and tried it from there, and I have downloaded the ISO files as well and booted from CD. None of these are successful, and the problem is becoming increasingly frustrating.
Any help is appreciated. Thanks in advance.
Community Manager
cdelse,
Did you remove the video card before attempting to flash the BIOS? If not try that.
According to the http://downloadmirror.intel.com/15061/eng/DG33TL_TechProdSpec.pdf TPS, the DG33TL supports PCI Express Rev 1.0a. Correct me if I am wrong, but the card you are using is PCIe 2.1.
I believe there is a power output difference between PCIe 2.1 and PCIe 1.0a. The firmware might address this, but I didn't see anything in the release notes.
Jason
Community Manager
Yes, I took the new card out and put the old one in the flash the BIOS (MSI GeForce 8400 GS). To my knowledge PCIe is fully backwards compatible, therefore any PCIe card should work it would just run at PCIe 1.0 speeds. I did my best to research this before purchasing the card.
Community Manager
Did you successfully flash the BIOS?
What is the status of your system now?
Community Manager
No, I'm saying this is what I've done from the start. It would be impossible to flash the BIOS with the 6670 in there because it will not even post.
Community Manager
Well, sorry, that's not clear from the OP.
You could try using the onboard video and take out any unnecessary components.
Community Manager
Sorry I can see that I wasn't clear. I'm getting video without issue though with the 8400GS, so I'm not sure how using onboard video would help?
Community Manager
cdelse,
It wouldn't. I've cross checked my logic with a colleague and I was a bit off.. embarrassing.
Did you try different BIOS revs as well as different flashing methods? I notice you only mentioned 326.2008 to 326.2009... that's the same BIOS rev from different years. Have you tried rev 407?
Jason
Community Manager
I have tried with every revision that is available on the Intel site. I get a "bytes overflow" error with each one, despite method used.
Edit: Also I apologize, the original text block had a typo. In that instance, I was trying to update to rev 0572. I've fixed it now.
Community Manager
The same colleague I corrected myself with says that he has only seen "bytes overflow" when using the wrong BIOS.
I hate to ask, but are you sure it's a DG33TL desktop board?
Community Manager
Yup, 110% positive. It's printed on the actual board and it what's CPU-Z reads it as. You'll also see the current version of the BIOS installed, matches the string for the newer versions I'm trying to install.
Community Manager
Is there any reason why the BIOS updates would think the board does not match? Is there anyway I can still force install the BIOS? Extensive Google searches don't reveal anything. :\
Community Manager
Would anyone have any further suggestions? MSI tech support is still of no help to me.
Community Manager
bump
Community Manager
Problem has become increasingly weirder...
After trying to install the BIOS via the jumper recovery method, the BIOS update fails (again). I turn off the computer, put the jumper back on, and turn it back on. Now the computer boots up with the new video card installed! Fantastic, problem solved I figure. Windows boots up, I download and install the latest drivers from the AMD site, and reboot. Lock up again at the BIOS splash screen. I do the same method to try to boot into Windows again (purposely fail the BIOS recovery update, reboot), and while BIOS posts successfully it now locks up on the Windows splash screen.
What is going on?
