Intel® Desktop Boards
Peer-to-peer support only
DG35EC Problem
Community Manager
Hai Everyone,
I am using an intel DG35EC board with core 2 quad processer and a 2 GB Ram.I use Windows 7 OS.Sometimes there is a problem when starting up my pc.the screen becomes blank.The light of the ram ( i dont know what that should be called.im sorry if it is wrong.).I recently found out that there is a problem with hibernation.I installed Windows 8 on the pc.at first there was no problem.But later i couldnt switch on my pc.then i switched off the hibernation option on win. 8.then there was no problem.Now i cannot use windows 8 currently.when i install the intel driver on the system,the screen is going blank and the monitor says not optimum mode and i cannot use it.i aborted the idea of windows 8 and installed windows 7.But currently it also becomes stuck after startup and when i am using the system..i think there is some ram problem.when i reinsert the ram from one slot to another there is no much problem.also when i take bios.the screen goes blinking.
pls. kindly let me knw what is the problem,possible causes and solns.
Silvia_L_Intel1
For Windows 7 on the DG35EC board, drivers are available; however support is limited due to discontinuance of the board.
The board does not support the installation of Windows 8, therefore the issues you are having could be related to compatibility with the operating system.
You may want to try with a BIOS update and check if the issue disappear
https://downloadcenter.intel.com/SearchResult.aspx?lang=eng&keyword=Intel%20Desktop%20Board%20DG35ec https://downloadcenter.intel.com/SearchResult.aspx?lang=eng&keyword=Intel%20Desktop%20Board%20DG35ec
regards,
Silvia_L_Intel1
regards,
